Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > General Car/Truck Questions & Discussion
Bill Douglas's Avatar
Understanding syncros
I have a '92 Toyota Corolla with a gearbox that graunches badly when cold. It's particuarly bad for the first few minutes then it's fine after 10 minutes of driving. I changed the gearbox oil to Castrol VMX and it still does it. I added "gear-up" additive to the oil and it still does it.
At first I thought it was a clutch problem, but a clutch place said it was fine and that the syncros were a bit worn and it needs THINER oil. The reason for this is the gearbox works fine when it has warmed up and the oil thined. I thought when syncros were worn you used a thicker, less slippery oil to make them grip and work quicker - I don't know.
If I do need a thinner slippery oil would Redline synthetic lightweight gear oil be a good bet? Or do you have some other ideas?
Thanks, Bill.
Old 10-13-2002, 06:14 PM
Author of "101 Projects"
Wayne 962's Avatar
It's worth a try. There are several different designs for transmissions - the slip-synchro one used in the Porsches may be different than the one in your Toyota. The transmission depends upon friction to spin up the gears. If the oil is really, really thick, it could be acting like too much of a bearing surface, kindof like the way it does in the engine along the mainshaft bearings...
-Wayne
Old 10-13-2002, 10:11 PM
Thanks Wayne. A chap at work said try Autotmatic transmission fluid. He said it is very thin and will get the metal to metal, that the Jap syncos need, to work better. It may ultimately knacker the gearbox but if I can get a few years out of it, it's worth a go.
Old 10-14-2002, 02:11 PM
Wayne 962's Avatar
Uhh, I would get a 2nd opinion on that. AutoTranny fluid is designed to work both as a lubricant, a coolant, and a hyrdraulic agent. I wouldn't use it in a manual transmission if I were you...
-Wayne
Old 10-14-2002, 02:17 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Second that. I'd use lighter-weight MTL, possibly something like the Redline synthetic. Second pref to that, a motor oil. ATF would be about my last choice...
--DD
Old 10-14-2002, 03:58 PM
SuperWheel's Avatar
I'll third that. I'd use old cooking oil before ATF - sounds like a hack.
Seriously, the Swepco stuff is what I swear by - I think that they have different weights - let me check...
Yes, check here:
http://www.drivewerks.com/catalog/car_care/Swepco.htm
Old 10-14-2002, 08:52 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
DO NOT, I repeat DO NOT run ATF in a manual gearbox. this is a bad thing. You will almost instantly burn it all up, and then you will have a nice big glop of sulphides floating around your gearbox, causing all sorts of corrosion, not to mention higher temperatures, as well as the general inability of ATF to provide any sort of lubrication for manual transmission gears.
Old 10-15-2002, 01:12 PM
Ok, four people whose opinions I respect say NO. No it is.
I'll source out some Redline Lightwieght oil.
Thanks Guys.
Old 10-15-2002, 02:52 PM
deltajetfixer's Avatar
Person who advised to try ATF might've had a Mustang like I did. The 93 V-8's ran Mercon in the 5-speed Getrag...
1995 C2 w/Tiptronic, Stongard, HID's
Old 10-17-2002, 07:36 AM
Sounds like typical Ford engineering.
Old 10-17-2002, 08:33 AM
F-O-R-D...means...
Fix-Or-Repair-Daily...
Old 10-17-2002, 10:06 AM
