Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
R53 spark plug change
Hi all,
Is using a torque wrench when replacing the spark plugs necessary, or will simple hand tightening with a socket wrench be enough?
Thanks in advance
Old 06-07-2022, 06:54 PM
Yes, plugs should tightened to specified torque. Gen 1 engines had a tendency to eject the plugs, taking the threads out with them. Torquing eliminates over-tightening, which may weaken and damage threads.
Old 06-17-2022, 01:03 PM
You can get away with not using a torque wrench, the critical thing is to not over-tighten because you could strip the thread out of the head. Then you would need a repair of that, I think with a helicoil.
Old 03-28-2023, 09:00 PM
always torque them 22-24 ft pounds.
1976 914
1986 951
Old 03-29-2023, 05:56 AM
