Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
sidewalksam (guest)
Guest
Posts: n/a
here is my question: when you jack the car both front and rear wheel come off the ground on the jack side. can you tell me how one gets just the front up on stands? I can imagine that you could use two jacks one on each side in synchrony but i envision as you get the stand on one side set when you move to the other side you would not be able to fit the jack underneath to place the second stand. thanks for the help
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Jacking Up Your MINI
Old 05-07-2013, 05:21 AM
Nick at Pelican Parts's Avatar
You can jack under the front crossmember, jacking just the front of the vehicle. be sure you are on the crossmember and not the engine oil pan or other items that could be damaged.
- Nick
