Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Oh, by the way. Instead of the GM puller you can use a caulking gun. Most everyone has one or two around their house.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Replacement
Old 05-22-2013, 04:24 AM
Nick at Pelican Parts's Avatar
Not a bad idea. Only issue would be the risk of damaging the slave cylinder. It is made out of plastic and too much pressure on the fitting side could damage it. Using the puller allows you to pull against the mounting flange that is designed to take stress.
- Nick
