Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
johnk (guest)
Guest
Posts: n/a
Thanks for the great guide, but I'm currently having trouble removing the outer ball joint from the steering knuckle. The two 13mm bolts Figure 1 came off easily, but the joint itself seems to be firmly stuck in there.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-19-2013, 05:53 AM
Nick at Pelican Parts's Avatar
The ball joint is likely stuck due to corrosion. Use a soft-faced hammer (such as brass) and tap the ball joint around the perimeter until it is free.
- Nick
