Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
bhaggen's Avatar
How do you get the rear trim panel off? The seat-back in the rear hinges thru a hole in the panel. And how does one get the window up if the regulator is bad? I can hear the motor running and "crunching" noises. I would appreciate more detailed info for the rear regulator. Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-05-2013, 03:36 AM
Nick at Pelican Parts's Avatar
To remove trim panel:
-Remove rear seat bottom and backrest.
-Open convertible top.
-Unclip rear side trim clip at front of B-pillar.
-Detach mucket from side trim at B-pillar.
-Remove fastener at front of B-pillar trim panel.
-Remove seat belt fastener on entrance cover strip.
-Lever out expansion rivets. Release screw.
-Unclip clips and remove side trim inwards and upwards.
-Lever out trim panel clips on inner window cavity cover strip.
-Carefully lever out window cavity cover strip with MINI special tool 00 9 317 towards top.
-Remove outer window cavity cover strip.
This is about as deatiled as I can get. I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799
- Nick
