Guest
Posts: n/a
What's the Drain Plug torque spec. for a 2012 Cooper Hatchback not S Model?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
R56 models are 30Nm (22 ft-lb). (M8 x 1.5 bolt) - Nick at Pelican Parts
Administrator
What is an "i10 s"? Do you mean a 2010 MINI Cooper S? In that case, it's the same as for all of the other 2nd-generation MINI Coopers. (2007-2013 model years, roughly.)
You drain the oil, replace the filter, and refill the oil. Access to the filter can be tricky; most people move the coolant overflow bottle out of the way for better access. The bottom of the oil filter housing has a hex head on it, and you use a large socket (I forget the size, something like 30mm?) to loosen it so you can remove the cartridge inside and replace it. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thread Tools | |
Rate This Thread | |
