Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Paul (guest)
Guest
Posts: n/a
What's the Drain Plug torque spec. for a 2012 Cooper Hatchback not S Model?
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-11-2013, 03:39 AM
Nick at Pelican Parts's Avatar
R56 models are 30Nm (22 ft-lb). (M8 x 1.5 bolt) - Nick at Pelican Parts
Hi..
How to change oil for i10 s model?pls reply
seo services | seo company
Old 10-17-2013, 04:08 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
What is an "i10 s"? Do you mean a 2010 MINI Cooper S? In that case, it's the same as for all of the other 2nd-generation MINI Coopers. (2007-2013 model years, roughly.)
You drain the oil, replace the filter, and refill the oil. Access to the filter can be tricky; most people move the coolant overflow bottle out of the way for better access. The bottom of the oil filter housing has a hex head on it, and you use a large socket (I forget the size, something like 30mm?) to loosen it so you can remove the cartridge inside and replace it.
--DD
Old 10-17-2013, 06:59 AM
