Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ted (guest)
Guest
Posts: n/a
I have an '06 non-S and the slave cylinder looks nothing like the one in the pictures and is mounted into the transmission housing on the front of the car. Do you still need to compress the slave cylinder when bleeding? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-18-2013, 06:06 PM
Nick at Pelican Parts's Avatar
Does is look like the one in the attached photo? You don't have to compress it, you can also pressure bleed the system which works quite well.
- Nick
Looks like same spot but the part looks like this number.
21-52-6-785-965-M33
Old 11-18-2013, 06:38 PM
