Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Cmstackx (guest)
Guest
Posts: n/a
What I mean is, is it possible to bleed it using the peddle with the slave cylinder still attached? And if it can't be bled with it still attached, do I have to remove the hydraulic line before I can compress the piston in or can I leave the hydraulic line attached while I compress the piston in with my Steering wheel tool?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-19-2014, 12:00 PM
Nick at Pelican Parts's Avatar
You can bleed the slave using the clutch pedal. As long as it is held all the way down, you can do it however you want.
- Nick
