Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Cmstackx (guest)
Guest
Posts: n/a
I have installed new clutch master and slave cylinders, I bought the Motive Power Bleeder and I'm still not getting the peddle I want. Is it possible to bleed the system with the slave cylinder attached? Also Can I compress the slaves piston in with it connected to the hydraulic line?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-19-2014, 11:59 AM
Nick at Pelican Parts's Avatar
Yes, I have compressed slave cylinders before when they would not bleed. As pressure builds, it will become difficult to gold the slave compressed, allow it to push out onto the clutch fork.
- Nick
