Guest
Posts: n/a
What I mean is, is it possible to bleed it using the peddle with the slave cylinder still attached? And if it can't be bled with it still attached, do I have to remove the hydraulic line before I can compress the piston in or can I leave the hydraulic line attached while I compress the piston in with my Steering wheel tool?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
You can bleed the slave using the clutch pedal. As long as it is held all the way down, you can do it however you want.
- Nick |
