Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brian B (guest)
Guest
Posts: n/a
Your Hot Tip section suggests replacing the brushes first. Where can I get info on that procedure?
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-16-2014, 01:02 PM
Nick at Pelican Parts's Avatar
Remove the alternator, then remove the regulator from the alternator. There should be a few small bolts. First check if the regulator is available. Give our parts specialists a call at 1-888-280-7799. They can help you find the right part.
- Nick
