Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
scotty (guest)
Guest
Posts: n/a
Would a weak master or slave cylinder give a short throw to the clutch arm? I only get about 14.5mm of throw at the end of the arm. Is that enough to disengage the clutch completely? Shifting is notchy and clutch engages close to floor.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-22-2014, 06:35 AM
Nick at Pelican Parts's Avatar
Yes, if the slave or master cannot hold the pressure needed to relieve the pressure plate, the clutch will not disengage.
- Nick
