Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
zamfield (guest)
Guest
Posts: n/a
Changed to Valero clutch kit, replaced with used transmission and added new slave & master. Slave doesn't push arm enough to be able to change gears... bled it multiple times. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-12-2014, 08:19 AM
Nick at Pelican Parts's Avatar
Double check the part number of the clutch you installed. It may be wrong. Also check if it looks like the slave is not extending far enough, You may have a faulty master or slave cylinder.
- Nick
