Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JeffL (guest)
Guest
Posts: n/a
What concerns me is the omission of the OE sleeve around the bolts. The sleeve serves an important purpose as alluded to in previous posts - keeps the bolts from cracking the valve cover. But, more importantly, the sleeves allow torquing of the bolts against the sleeve, and not the rubber donut washers. That way the washers isolate the vibration but are not completely squashed. Why aren't the manufacturers of these aftermarket coils seeing this? My advice would be to drill out the metal sleeve and use the original so the attachment is correct. Any thoughts? Any coils that actually accept the OE bolts?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-19-2014, 03:59 PM
Nick at Pelican Parts's Avatar
To prevent cracking, I believe you have to transfer the rubber insulators over from the old coils.
- Nick
