Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mongoman7071 (guest)
Guest
Posts: n/a
update: By powering up and placing the LHS window switch -Down, the motor worm screw ....unscrewed itself from the Regulator. Ok motor obviously works . The big problem still exists, how to get the window to come down with a regulator that is probably Jammed. Any Ideas would be appreciated.
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-19-2014, 04:07 PM
Nick at Pelican Parts's Avatar
If the regulator is faulty, cutting the cable will release it.
- Nick
