Guest
Posts: n/a
update: By powering up and placing the LHS window switch -Down, the motor worm screw ....unscrewed itself from the Regulator. Ok motor obviously works . The big problem still exists, how to get the window to come down with a regulator that is probably Jammed. Any Ideas would be appreciated.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
If the regulator is faulty, cutting the cable will release it.
- Nick |
Thread Tools | |
Rate This Thread | |
