Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Phil D (guest)
Guest
Posts: n/a
Actually, I have not been able to remove the throw out fork. Here is another picture which shows the welded part more clearly. My guess this is a modification the previous owner made. Other than cutting the throw out fork shaft, I cannot think of another way to remove it.
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-16-2015, 01:10 PM
Nick at Pelican Parts's Avatar
Ok I see it better now.
On the far side away from the lever, on the right of the image. There is a pin that release the shaft. Then slide it out and remove it along with the bushings. I would replace the shaft. bushings and pin.
- Nick
