Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
KirbyGo (guest)
Guest
Posts: n/a
i changed my transmission fluid today on my R53 2005 mini cooper S and there seems to be a leak. I tightened the fill and drain plug to 32 ft lbs just like the article says. Should i tighten them even more? or will that cause the plugs to fail like mentioned in a previous comment?
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-28-2015, 04:08 AM
Nick at Pelican Parts's Avatar
Do not over-tighten the plug. Try replacing it is the leak is from there.
- Nick
