Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Chris S (guest)
Guest
Posts: n/a
Can the pre 12/2003 upper motor mount be replaced by the post 12/03 style. By removing the extra motor mount bracket, are the correct bolts holes in place for the 16mm bolt that goes in the frame for the newer style mount
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-17-2015, 05:09 AM
Nick at Pelican Parts's Avatar
I do not know. I would think the long block is the same, with the same holes. But i can't be sure.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
