Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Challo (guest)
Guest
Posts: n/a
Is there a special way to remove the motor from the regulator? I bought a second hand regulator but the motor is knackered. The Motor on the old regulator is good so I want to swap over.
When I removed the good motor from the broken regulator the gearbox came off and released all the cables. Anyway to get around it?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-12-2015, 11:40 AM
Nick at Pelican Parts's Avatar
Remove the fasteners, then twist as you pull up.
- Nick
