Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Rane (guest)
Guest
Posts: n/a
Thanks for the instructions, but this part is confusing me: "You'll want to fill the engine until you start to see coolant coming out of both vent screws. Once you see this, close both of the screws. Keep filling the reservoir until it no longer drain into the filler neck. Now remove the reservoir and close the vent screws."
It says to close the screws and then it says to do other stuff and close them again.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-17-2015, 08:49 AM
Nick at Pelican Parts's Avatar
Fill until coolant flows out of the vents, then close them. They now remain closed.
I will have the article updated, to remove the confusion. Thanks for catching that.
- Nick
