Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Sherlock (guest)
Guest
Posts: n/a
Hi, I have a mini one diesel 1.4, I have a few problems!
I'm getting a bubbling noise behind dash, my rad fan comes on all the time, no heat from heaters, topped up with 2ltrs of water over 700miles, had head gasket checked with the colour change test on header and came back ok. Any ideas please. Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-17-2015, 09:51 AM
Nick at Pelican Parts's Avatar
Could be a coolant leak, allowing air in the system. Then you hear it in the heater core. That is if the head gasket checked out OK.
- Nick
914 Geek
There's definitely air in the system. How it got there is the real question. Check around the water pump and the thermostat housing. The latter really likes to leak on the 2007-2013 Cooper models; not sure about the diesel but it is worth looking.
--DD
Old 07-17-2015, 02:36 PM
