Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mike (guest)
Guest
Posts: n/a
These are great instruction with one missed note. On both of my replacement window motors, they ran backwards. It's a simple correction, but extremely frustrating if you're already at step 40 when you figure it out.
The fix is to remove the 4 screws holding the motor casing in place, lift about 6mm and then rotate 180 degrees. Press back down and re-install screws refer to attached picture.
I suggest testing the motor in the harness before installing on the window regulator to save the head ache. Easy fix and much less frustrating than finding out after install.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-17-2015, 09:54 AM
Nick at Pelican Parts's Avatar
Thanks for the additional info. We appreciate it.
- Nick
