Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gary (guest)
Guest
Posts: n/a
Sorry for the explanation. The car moves forward normally in first but seems to rev higher then it should before switching to second gear. If I switch to paddle shift the gear changes are immediate. I was told at the dealer that the CVT transmission has no filter...is this true?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-21-2015, 05:17 AM
Nick at Pelican Parts's Avatar
That is correct, no filter.
You may need an adaptation. I would grab a repair manual with the procedure, it has to be done exactly right. Give our parts specialists a call: 1-888-280-7799
- Nick
