Guest
Posts: n/a
Sorry for the explanation. The car moves forward normally in first but seems to rev higher then it should before switching to second gear. If I switch to paddle shift the gear changes are immediate. I was told at the dealer that the CVT transmission has no filter...is this true?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
That is correct, no filter.
You may need an adaptation. I would grab a repair manual with the procedure, it has to be done exactly right. Give our parts specialists a call: 1-888-280-7799 - Nick |
Thread Tools | |
Rate This Thread | |
