Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
ilio (guest)
Guest
Posts: n/a
Your instructions and photos are great! The one issue I have is that after I installed everything, the window "squeals" when rolling down the last 3-4 inches. No sounds when the window goes up. I don't know what to adjust to get rid of whatever is rubbing or binding. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement
Old 12-22-2015, 04:44 AM
Nick at Pelican Parts's Avatar
Check if the window glass is on the wrong side of the seal toward the bottom of travel. I have seen them flip out and make noise / bind.
- Nick
