Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Salah (guest)
Guest
Posts: n/a
Hi, I got P0108 code for the MAP sensor. I replaced the sensor and cleared the code. When I start the car, turn off, and restart, the code comes back again. any ideas? thank you
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Pressure Sensor Replacement
Old 01-05-2016, 07:42 AM
Nick at Pelican Parts's Avatar
Check the wiring for the sensor to the DME. Also be sure you replaced the right sensor.
- Nick
