Guest
Posts: n/a
Is this process only recommended if you have had some mechanical training? I have had almost no experience with engines but the process doesn't look impossible. I also don't want to spend 1700 taking it to a mechanic. Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Timing Chain Guides Replacement |
If you are mechanically inclined, you should be able to perform the task.
- Nick |
