Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Allen (guest)
Guest
Posts: n/a
Is this process only recommended if you have had some mechanical training? I have had almost no experience with engines but the process doesn't look impossible. I also don't want to spend 1700 taking it to a mechanic. Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Timing Chain Guides Replacement
Old 03-09-2016, 11:58 AM
Nick at Pelican Parts's Avatar
If you are mechanically inclined, you should be able to perform the task.
- Nick
