Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Originally Posted by Luccia at Pelican Parts View Post
I've seen more than a few times where this issue has popped up so I wanted to share some part information with everyone. As you know, a lot of plastic components under the hood of MINI's can get brittle and break. Recently, I've seen more than a few individuals indicate that their R56 thermostat coolant temp sensor connector has broken, but there is no listed part number for that connector. From what I have found, the oil pressure connector is the SAME as the thermostat coolant temp sensor connector. The 2 pin plastic connector for the oil pressure connector is part number 12-52-7-542-850-BOE HERE, which is #13 on the image below:
This is what it looks like.
Along with that connector you will need 2 of these wires 61-13-0-005-199-M9 HERE. Image of one of them below. You will need to splice them into the wiring harness.
Hope this helps someone with this issue in the future. Let me know if you have any questions.
Hi,
I know this thread is old, but could you tell me which wires should go in which port if the key side is facing towards you? There's a yellow wire and a white wire, and I don't want to cross them.
Thanks!
Old 09-09-2018, 05:37 PM
Hi,
I know this thread is old, but which wires go in which port if the key side is facing you? There's a yellow wire and a white one, and I don't want to cross them by accident.
Thanks!
Old 09-09-2018, 05:43 PM
Administrator
Luccia at Pelican Parts's Avatar
I am not sure. Best bet is to look at how the old connector is hooked up and make sure to hook up the new connector the same way.
Old 09-10-2018, 03:35 PM
61-13-0-005-199-M9 is the wrong part. The terminals for the temperature sensor connector are
BUSHING CONTACT(m) Part #: 12-52-7-543-260-BOE
or
Bushing Contact(Mini)(m) Part #: 12-52-7-555-721-BOE.
They are the same, except that the -260 part has an extra flag that needs to be trimmed off (and costs a little less).
You will need to strip the end of the old wires, and crimp the terminal on. Study the connector first, and make sure the parts of the connector that are behind the terminal are there before you do your crimping. The crimper I use is something like this. Avoid crimping the rectangular part of the terminal, and it should snap right into the connector.
It doesn't matter, functionally, which wire goes where—the sensor is a variable resistor, and the resistance is the same whichever way you measure.
MB
Old 06-18-2020, 12:47 PM
Thank you so much Luccia on the alternative plug for the coolant sensor. Your oil pressure plug works like a charm.
Old 08-30-2020, 04:24 AM
Administrator
Terrific! So glad this could help you in a time of need.
Old 09-01-2020, 01:20 PM
Question on reverse wiring on ECT sensor:
Are there any impact on reversing the 2 wires that is leading to the ECT sensor? I got a new ECT sensor that came with my new thermostat and housing, replaced the plug and wiring as mentioned above and now I'm getting DTC code of P0117. Wondering if new ECT sensor can be defective. I still have my old sensor and was wondering if I should stick with my old sensor. Any thoughts on fixing the P0117?
Old 09-17-2020, 05:25 AM
Exclamation Bad ECT Sensor Wiring
Luccia or anyone else,
I have a P0117 and it's telling me that I have a low circuit input on my ECT sensor. I have a brand new ECT sensor, wires and plug connector which I bought using your suggestion from you earlier comments. I even tested the new ECT sensor just to make sure that it is not defective and it works fine. My OBD II machine is telling me that "I HAVE A BREAK or GROUNDED wiring" for my ECT and was wondering if there is a wiring harness I could buy that leads to my ECT sensor from the DME terminal OR could someone tell me which pin number on the harness or DME so I could run a new wire that would bypass the break or grounded section in order for my DME to pick up the signal again. Could you help me? That would be great if you can.
Old 09-21-2020, 02:03 AM
Hi all, just joined the forum, and have lots of questions on a 2008 mini cooper hatchback, r56,N14
replaced t-stat housing, forgot where the 3 plug sensors go??? one for temp, one for t-stat, one for oil.
One has a green spacer ( for lack a better word ) another has a grayish spacer, only one has single wire going into the connector, I know I should of marked them first, but being in a hurry, I did not, so I am here looking for HELP If you can be so kind as to not mention my not marking them or taking pics I'd appreciate it.Seems weird that a plug has only 1 wire going into it??
Thanks in advance for any help you can offer RUDY
Old 12-06-2020, 09:40 AM
Originally Posted by vhsnap View Post
Hi,
Thanks!
If you're looking straight down at the sensor, the Yellow wire goes on the left. Yes it does matter if you have the Yellow wire on the right side of the plug. I know this because when I had the wires reversed, the computer read the ECT as 284 degrees Fahrenheit even when my engine was stone cold. So yes, it's important which wire goes where.
Old 12-06-2020, 02:39 PM
Coolant sensor connector
Just wanted to point out this connector does not work on 2013 Mini Cooper. The plug is too big and key is oriented wrong. Unfortunately, I did not find this out until receiving the part and tried to use it. Pretty sure my son's hatchback is an R56.
Old 12-21-2023, 08:45 AM
