Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Bing (guest)
Guest
Posts: n/a
Do you need to have the steering aligned after replacing the lower control arm bushing?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Control Arm Bushing and Ball Joint Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 06-15-2016, 01:36 PM
Nick at Pelican Parts's Avatar
Not necessarily. But it is a good idea to do so. when done, if the vehicle drives straight and the steering wheel angle hasn't changed, you should be OK.
- Nick
