Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
link (guest)
Guest
Posts: n/a
I seem to be misunderstanding something in this procedure. After getting the new pan and filter back on, I was only able to add 1.5qts before it started spilling out. No amount of starting and shifting through the gears would allow me to add any more I filled through the drain using a VW tool. Is the fill and check procedure after running through the gears supposed to be done while the vehicle is still running or cold?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article
Old 07-12-2016, 07:38 AM
Nick at Pelican Parts's Avatar
When you change through the gears, the engine has to be running.
- Nick
