Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Justin (guest)
Guest
Posts: n/a
On the last step, it says to install the pre-tensioner tool and tighten to 0.6 NM? Am i reading that right? I dont even have a torque wrench that will go that low. You sure you dont mean 6 NM? .6 seems like nothing, not even finger tight.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-15-2016, 06:32 AM
Nick at Pelican Parts's Avatar
0.6 Nm or 5 in-lbs. That is correct.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
See if we may have a torque wrench that will work for you here: Torque Wrenches - PelicanParts.com
Old 09-15-2016, 09:08 AM
