Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
bmeyer (guest)
Guest
Posts: n/a
Is the method for removing the Countryman R60 Serpentine Belt the same as the R56?
my 2011 countryman Base model has developed a screeching sound that's not the bakes so I was going to check out the belt tensioner bearings.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Serpentine Belt Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-22-2016, 05:05 PM
Nick at Pelican Parts's Avatar
If the engine is the same, the procedure for removing the belt will be similar. Accessing it will be different.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
I'm thinking the Countryman might be a bit different from the R56, but you can give the tech article a shot to see if it may help. Also, while you do it, maybe photograph and take notes of the differences and then you can submit it to get 10% off your next parts order with us.
Details here: Enthusiast Tech Article Submissions - Pelican Parts
Old 09-29-2016, 09:17 AM
