Guest
Posts: n/a
I have a 2003 Mini not turbo and have three 10 mm bolts holding it in place from inside the box. When I removed the two bolts on the right side, I was unable to remove the third bolt in the back left corner. It spins but does not come up. That is the point where the box cannot be lifted out. Any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R50 Airbox and Battery Box Removal (2001-2006) | Pelican Parts DIY Maintenance Article |
Sometimes I apply upward pressure when loosening. This can jam the loose nut below in place enough to loosen it. If not, you'll have to cut or break it.
- Nick |
Administrator
If you have to cut it off the battery box tray M6X21 bolts here: Pelican Parts - Torx Bolt With Washer
Thread Tools | |
Rate This Thread | |
