Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Andy (guest)
Guest
Posts: n/a
Exact same problem as David. Top left bolt in battery tray rusted and spinning, any help other than cutting plastic surrounding it would be greatly appreciated.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R50 Airbox and Battery Box Removal (2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-01-2016, 04:20 PM
Nick at Pelican Parts's Avatar
Sometimes I apply upward pressure when loosening. This can jam the loose nut below in place enough to loosen it. If not, you'll have to cut or break it.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
If you have to cut it off the battery box tray M6X21 bolts here: Pelican Parts - Torx Bolt With Washer
Old 10-03-2016, 08:32 AM
