Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
BrookelynMini05noob (guest)
Guest
Posts: n/a
How to check manual transmission fluid
Hi. I have a Mini Cooper 2005. I was wondering if I can access the bolt needed to just check the Transmission fluid from under the hood? Or will I have to jack my car up to get underneath?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-09-2016, 08:35 AM
Nick at Pelican Parts's Avatar
No, you have to access from below.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Figure #4 in the tech article shows you where you need to access it under the vehicle.
Transmission fluids if needed: http://www.pelicanparts.com/catalog/SuperCat/MN01/MN01-Transmission-Clutch.htm
Old 10-10-2016, 10:13 AM
You can also remove the reverse light switch on top of the transmission and check the oil.
Old 10-10-2016, 10:26 AM
