Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
What wore out my Alternator?
Removed new alternator bench tested 8v ..
.. chuncked that now have a. New new one
Any issue that might have fried stock one and
Replacement alt so I don't install third and screw
It up . Original only put out 11v , replacement 8v
is second one a bad build and not a elec. Issue
Don't see any blatently bad wiring . Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-09-2016, 07:38 AM
Nick at Pelican Parts's Avatar
Nothing usually kills them, they usually wear out.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
How many miles are on your MINI and is that the original alternator? If so, it's not uncommon for this item to go bad at some point. Just make sure to replace with the correct one. I'm a bit confused about what you wrote. Are you saying that you're now having an issue with the new one you installed?
Alternators - Mini Cooper & Cooper S (R50/R52/R53) - Charging System & Battery - Page 1
Old 10-10-2016, 08:50 AM
- Nick
The new one was bad from the box was just
Worried that there might be a elec. Issue which
Could fry it, so thanks nick I will install.and
The mini has 30k on it
Old 10-10-2016, 09:03 AM
