Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Bob (guest)
Guest
Posts: n/a
Thanks for posting this - good tip about removing the slide bolt. I cleaned them off and wiped on some new lubricant. There must a difference in some of the Mini models as our R56 2010 required a 16mm thin wall wrench. Good thing too as I did not have a 17mm that would fit!
Biggest pain I found was attaching a new wear sensor - had to remove a lot of screws to pull out the wheel well cover!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Front Brake Pad Replacement (R56 2007-2013) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 09:41 AM
Nick at Pelican Parts's Avatar
Thanks for the additional info and feedback. We appreciate it.
- Nick
