Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Freddie Flint. (guest)
Guest
Posts: n/a
R56 IBS unit location on battery
Hello,
I'm replacing the battery on a 2009 mini &want to check if it has the IBS fitted, in your figure 3 it says the purple arrow points to the L shaped IBS unit but I cannot see the purple arrow, is the IBS unit fitted in figure 3?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 10:38 AM
Nick at Pelican Parts's Avatar
See fig 7. it is the black plastic piece in that photo.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
In figure 3 it's the L shaped black box above the negative terminal where the green arrow is pointing. Sometimes IBS units don't have the black box covering the unit so if there is something in that shape above your negative terminal you have the IBS unit.
Old 12-20-2016, 11:22 AM
