Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Rob (guest)
Guest
Posts: n/a
Where is the am diversity amplifier on an R55? I am only having issues with the am which cut out on the way to work one morning. Any tips?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Radio Antenna Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 09:39 AM
Nick at Pelican Parts's Avatar
What year and model? I can see if I have that info.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Post the last 7 digits of your Clubman's vin as that'll help. Does FM still work fine? You could possible have a diversity antenna amplifier failure or maybe some sort of antenna connection issue somewhere. Do you have a Bentley Manual? I wonder if the info might be in there for the location on the R55.
Bentley Manual: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Books & Technical Documentation - Page 1
Not sure this would help, but maybe: The Hack Mechanic Guide to European Automotive Electrical Systems - PelicanParts.com
Old 12-22-2016, 08:49 AM
