Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
docracing (guest)
Guest
Posts: n/a
Nick, firstly...thanks for your time and consideration....helped greatly....had replaced thermostat last year....you know they are subject to leaking....car inside heating system comes up immediately and high speed radiator fan comes on and have to pull relay...sorry for not forwarding info at first....too much Christmas eggnog...like my BMW is there a second thermostat sensor, does the mini possess same...oh, Happy New Year
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 01-02-2017, 06:14 AM
Nick at Pelican Parts's Avatar
if the thermostat was replaced, it could be faulty again or the connector is the issue.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Make sure the connectors were plugged in correctly with the thermostat. If they're switched, it'll trigger a fault. I see this often when individuals replace the t-stat. You can also plug into the DME and see if your MINI is getting to operating temp, 220F.
Here is our thermostat replacement article to see if your sensors are plugged in correctly: MINI Cooper R56 Turbocharged Engine Thermostat Replacement (2007-2011) | Pelican Parts DIY Maintenance Article.
Old 01-03-2017, 09:15 AM
