Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
hoodmeister (guest)
Guest
Posts: n/a
Removed the alternator to do the SC oil change and am finding that the clearance holes for mounting the alternator allow lots of slop. How does one verify that the alternator is aligned relative to the other pulleys? Just eyeball it? It would be very easy to get it pretty far off if you're not careful. Any tips? Thanks
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 01-25-2017, 12:44 PM
Nick at Pelican Parts's Avatar
Hand tighten all three fasteners before the final tighten. Check that the pulley is aligned with the crank pulley. Then tighten to final torque.
- Nick
