Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
kabjamison (guest)
Guest
Posts: n/a
Can you use a 30mm wrench instead of the special tool 11 9 280? Some of your tech articles on crankshaft adjustment are shown a 30mm wrench.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 02-06-2017, 06:29 AM
Nick at Pelican Parts's Avatar
No, that tool bolts to the crankshaft hub to hold it. You will need it.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
All the tools are listed at the bottom of the article before the figures. You can also see if you can rent a tool kit or borrow one from a friend.
Old 02-07-2017, 08:02 AM
