Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
I have an '09 Mini JCS Clubman. The left front cv axle is bad. It is absolutely stuck in the hub. I've used pullers and heat...it's not budging. Not worried about damaging the existing axle since it's already bad anyway, but do you have any suggestions?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Drive Axle Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-08-2017, 04:21 AM
Nick at Pelican Parts's Avatar
Remove it with the bearing, then replace the axle and bearing.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Is your Clubman a JCW or Clubman Cooper S? There is no such thing as a JCS. Just want to make sure, but it looks like the part numbers are the same for the Cooper S and JCW:
Wheel bearing (comes with new hub): 2009 Mini Cooper S Clubman Wagon - Axles, Bearings & Differential - Page 3
Old 03-08-2017, 10:57 AM
