Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
xavi.creus (guest)
Guest
Posts: n/a
Is it possible to remove the ball joint that its attached to the subframe? Which is the best way?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Front Ball Joint Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 07:03 AM
Nick at Pelican Parts's Avatar
From the control arm? I don't believe so. it has to be replaced with the control arm. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
