Guest
Posts: n/a
Is it possible to remove the ball joint that its attached to the subframe? Which is the best way?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Front Ball Joint Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
From the control arm? I don't believe so. it has to be replaced with the control arm. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
Thread Tools | |
Rate This Thread | |
