Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
NagyR56 (guest)
Guest
Posts: n/a
Hi,
I'm also having p0014 code.
We have checked everything on the list, another thing that comes to my mind is possible bad wiring, or some kind of electrical problem.
could you please give me some kind of wiring diagram or just tell me what voltage or electrical resistance values should I be geting on both solenoids, for both wires?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 08:12 AM
Nick at Pelican Parts's Avatar
There are no resistance values available for the solenoids. They are 12 volt solenoids, so one side ground, one 12 volt. You can monitor function using a lab scope, look at control circuit voltage current.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
What is "everything on the list" that you have checked/done?
Some info in these threads:
http://forums.pelicanparts.com/bmw-mini/952209-question-cooper-valvetronic-faults.html
http://forums.pelicanparts.com/bmw-mini/949432-question-vanos-solenoid-replacing.html
Old 04-26-2017, 08:59 AM
